AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Replacing a turntable motor for a spacemaker XL1400
Hello, I would like to replace the turntable motor in a spacemaker XL1400 because it makes a weird noise (as if it was dephased). I have 2 possible candidates: - square shape WB26X10037 - D-shape AP2024962 I guess I will find out when the motor will be removed. But I'm not sure how difficult the task will be. The diagram shows that I shoud remove the bottom with the grease filters and lights: Replacement parts for GE JVM1440WD001 | AppliancePartsPros.com And what should I expect then? A direct access to the motor?
Microwave Repair
