The washer door inside has four holes from the springs inside, and the bottom is cracked and has black marks from rubbing. The boot has hole in the side, so the washer in leaking all over the floor. Because of the black rubbing marks on the bottom of the inside door, I am wondering if something else major can be wrong of if just replacing the inside door and boot will solve the problem. Thanks Diane
THIS FORUM IS DEAD!!!!!!! |
