dianesan
#1 Posted : Tuesday, May 27, 2014 4:56:52 PM(UTC)
dianesan
The washer door inside has four holes from the springs inside, and the bottom is cracked and has black marks from rubbing. The boot has hole in the side, so the washer in leaking all over the floor. Because of the black rubbing marks on the bottom of the inside door, I am wondering if something else major can be wrong of if just replacing the inside door and boot will solve the problem.
Diane
#2 Posted : Sunday, June 1, 2014 5:10:00 AM(UTC)
Here are your parts.
Parts for Maytag MAH5500BWW Washer - AppliancePartsPros.com
Below is a link to a manual.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...downloads;sa=view;down=1
Without being there I cannot say perhaps the manual will be helpful to you.
You did not mention excessive vibration or any other problems with the unit so odds are that replacing the parts will at least get you an additional year or two out of the unit.
Diane (Oven Repair (including Ranges and Cooktops))
by umpmom55 8/18/2011 11:52:12 AM(UTC)
Diane needs help with oven (Oven Repair (including Ranges and Cooktops))
by Diane Gober 1/22/2011 8:17:48 AM(UTC)
homeowner Diane (Oven Repair (including Ranges and Cooktops))
by dianeb 1/22/2009 9:08:00 AM(UTC)
by dianedennis2@yahoo.com 9/10/2008 7:43:27 AM(UTC)
