roars-literally, when spinning. have replaced bearings, suspension rod supports and am now thinking I need to replace the transmission. Every forum and blog I read says it is the bearing, but we have replaced the bearing---any thoughts?
Groups: Expert
You replaced the tub bearing? Most likely the lower transmission bearing is bad. It's a bit of work but can be replaced versus replacing the transmission. You can visually check the bearing to see if it is rusted out. Eric
I will have to see how to check that out. Not sure how but it will save about $150 if that is it. Do you know of any diagrams or videos of that replacement? Thank a lot, we thought we had changed the only bearing.
Groups: Expert
awesome, thank you so much
how do I verify this is right bearing for my washer?
I find bearings with same # but they say 6205-2RS Sealed Ball Bearings - 25x52x15mm is this the same? thank you so much for your help!
Groups: Expert
No, it will not fit on the transmission shaft. You need the special bearing that I suggested which has a 1" bore. The 25mm bearing is 63/64" and is just a hair too small to fit.
Eric
thanks--can't believe they want $8 to ship. will look elsewhere
do you know the size socket I need to remove nut? I am borrowing it and need correct size--ordered from your recommended place-thanks
