3 Pages123>
jaws
#1 Posted : Wednesday, May 21, 2014 1:29:39 PM(UTC)
jaws
roars-literally, when spinning. have replaced bearings, suspension rod supports and am now thinking I need to replace the transmission. Every forum and blog I read says it is the bearing, but we have replaced the bearing---any thoughts?
fairbank56
#2 Posted : Thursday, May 22, 2014 3:53:20 AM(UTC)
fairbank56
Groups: Expert
You replaced the tub bearing? Most likely the lower transmission bearing is bad. It's a bit of work but can be replaced versus replacing the transmission. You can visually check the bearing to see if it is rusted out.
Eric
UserPostedImage
jaws
#3 Posted : Thursday, May 22, 2014 4:19:46 AM(UTC)
jaws
I will have to see how to check that out. Not sure how but it will save about $150 if that is it. Do you know of any diagrams or videos of that replacement? Thank a lot, we thought we had changed the only bearing.
fairbank56
#4 Posted : Thursday, May 22, 2014 9:02:53 AM(UTC)
fairbank56
Groups: Expert
Yes, I created this webpage on how to disassemble the lower part of the transmission to get at the bearing.
http://home.comcast.net/~fairba...sion/GEtransmission.html
And here is a source for the bearing.
6205-2RS-1 Special Size Ball Bearing 1 inch x 52 x 15 mm
Eric
jaws
#5 Posted : Thursday, May 22, 2014 9:13:04 AM(UTC)
jaws
awesome, thank you so much
jaws
#6 Posted : Saturday, May 24, 2014 9:35:56 AM(UTC)
jaws
how do I verify this is right bearing for my washer?
jaws
#7 Posted : Saturday, May 24, 2014 9:42:31 AM(UTC)
jaws
I find bearings with same # but they say 6205-2RS Sealed Ball Bearings - 25x52x15mm is this the same? thank you so much for your help!
fairbank56
#8 Posted : Saturday, May 24, 2014 1:12:51 PM(UTC)
fairbank56
Groups: Expert
No, it will not fit on the transmission shaft. You need the special bearing that I suggested which has a 1" bore. The 25mm bearing is 63/64" and is just a hair too small to fit.
Eric
jaws
#9 Posted : Monday, May 26, 2014 2:51:58 PM(UTC)
jaws
thanks--can't believe they want $8 to ship. will look elsewhere
jaws
#10 Posted : Sunday, June 1, 2014 1:57:42 PM(UTC)
jaws
do you know the size socket I need to remove nut? I am borrowing it and need correct size--ordered from your recommended place-thanks
3 Pages123>
