hi my refrigerator is too warm but my freezer is good this is a frigidaire gallery side by side door. please how can I fix it? thank you
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Can you see frost build up on the rear panel in the freezer? Does the fan inside the freezer work? Make sure the condenser (on the back and under the refrigerator) is clean and the fan next to the compressor is running. Post the results. Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FRS26ZSHB3 | AppliancePartsPros.comGene.
