Replaced erc and still getting F O error code key pad is frozen the only thing that works is the clock
A model number may help others help you. Find your model number - AppliancePartsPros.comLooking up F0 fo GE I get a couple definitions. A bad control board. A stuck key on the control panel (keypad) So if your unit has a separate keypad, remove power from the stove, unplug the keypad then reapply power. If the error does not re-occur then odds are it is a bad keypad. |
THIS FORUM IS DEAD!!!!!!! |
