PatriciaPeach
#1 Posted : Tuesday, October 20, 2009 12:49:17 PM(UTC)
PatriciaPeach
when you try to put the machine ..on heavy duty it won't It stays on the normal cycle ..The lights blink off and on :confused: :confused: :confused: HELP
PatriciaPeach
#2 Posted : Tuesday, October 20, 2009 12:54:07 PM(UTC)
PatriciaPeach
Originally Posted by: PatriciaPeach Go to Quoted Post
when you try to put the machine ..on heavy duty it won't. It stays on the normal cycle ..The lights blink off and on :confused: :confused: :confused: HELP
#3 Posted : Tuesday, October 20, 2009 7:22:46 PM(UTC)
If there was no error codes shown then most likely the problem is a bad key pad which is a part of the console. There is a small chance for the control board to be bad as well. I would start with the console replacement. If you need the correct part number for the console then post the color of it.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAH5500BWQ | AppliancePartsPros.com
