Hello When I pulled out the filter on top of my dryer, a plastic "to go" lid fell into it. I have tried to fetch it out and i eeven turned on the dryer for a second. It made a noise and stopped. I have removed the back and stuck my hand up through the hole but don't feel anything. Should I take off the front? I am a woman and don't have a man to help. I can call a friend. Would you please help me? Thank-you Betty
Here are your parts Parts for Maytag NED4500VQ0 Dryer - AppliancePartsPros.comI am not sure what hole you stuck your hand into so am assuming it was exhaust and you probably could not reach it. Below is a video. It is for replacing the blower wheel which you do not want to do but it should still be helpful to you. You want to remove the blower housing. I would undo the top as shown just to be sure you do not snag any wires when removing/reinstalling the blower housing. Do not remove the front. Then remove the rear cover and the blower housing so you can remove the object. Part number: AP2997251
THIS FORUM IS DEAD!!!!!!! |
