imroc
#1 Posted : 11 years ago
imroc
Hello!
Our ice maker had stopped operating all together. I took the cap off the motor control 'board' and tested the terminal points and had 0 volts from line to neutral. When I unplug the board from the harness and removed the load, i have 120 volts. Continuity exists across the tray thermostat. I thought maybe that the board connectors and/or harness weren't getting good contact, so I tested the power at the rear harness. 120 volts across line and neutral with no load, 0 volts when plugged in and loaded. I'm an HVAC/R tech, but I don't dabble in appliances much. I can't find a wiring diagram/schematic on or under the fridge (it was used). I'm presuming there's a defective control board somewhere. This is the type of freezer that has a door sensor as well with a spring loaded flip switch. Any help from you appliance pro's would be greatly appreciated!
John
imroc
#2 Posted : 11 years ago
imroc
update.
I took the ice maker out and put a widow-maker on it. The motor is turning with no problems and appears to be operating fine at the test points. Can anybody point me toward a wire diagram of the refrigerator so I can move on to the next suspected component(s)?
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 10 months ago
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay about a year ago
Maytag Ice Maker Issues (Refrigerator & Freezer Repair)
by maxxfusion 2 years ago
Ice maker issues. (Refrigerator & Freezer Repair)
by Guest 3 years ago
LG Ice Maker Issues (Refrigerator & Freezer Repair)
by rcn01 4 years ago
Ice Maker Issues (Whirlpool WRF736SDAM14) (Refrigerator & Freezer Repair)
by aarondahmen 5 years ago
Kitchenaide side by side Ice Maker issues (Refrigerator & Freezer Repair)
by Dedalus 7 years ago
Ice maker issues (Refrigerator & Freezer Repair)
by swoldhagen 12 years ago
ice maker issues (Refrigerator & Freezer Repair)
by shawk468 12 years ago
by smhlbailey@hotmail.com 13 years ago
KitchenAid Refrigerator Ice Maker Issues (Refrigerator & Freezer Repair)
by KitchenAid-Sucks 13 years ago
by diggo 13 years ago
by scottwalter 13 years ago
Samsung Ice maker issues (Refrigerator & Freezer Repair)
by danlee 14 years ago
by pe34 14 years ago
