imroc
#1 Posted : Thursday, April 10, 2014 8:04:12 AM(UTC)
imroc
Hello!
Our ice maker had stopped operating all together. I took the cap off the motor control 'board' and tested the terminal points and had 0 volts from line to neutral. When I unplug the board from the harness and removed the load, i have 120 volts. Continuity exists across the tray thermostat. I thought maybe that the board connectors and/or harness weren't getting good contact, so I tested the power at the rear harness. 120 volts across line and neutral with no load, 0 volts when plugged in and loaded. I'm an HVAC/R tech, but I don't dabble in appliances much. I can't find a wiring diagram/schematic on or under the fridge (it was used). I'm presuming there's a defective control board somewhere. This is the type of freezer that has a door sensor as well with a spring loaded flip switch. Any help from you appliance pro's would be greatly appreciated!
John
imroc
#2 Posted : Thursday, April 10, 2014 9:31:33 AM(UTC)
imroc
update.
I took the ice maker out and put a widow-maker on it. The motor is turning with no problems and appears to be operating fine at the test points. Can anybody point me toward a wire diagram of the refrigerator so I can move on to the next suspected component(s)?
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
Maytag Ice Maker Issues (Refrigerator & Freezer Repair)
by maxxfusion 6/2/2023 4:42:14 AM(UTC)
Ice maker issues. (Refrigerator & Freezer Repair)
by Guest 12/3/2021 6:40:16 AM(UTC)
LG Ice Maker Issues (Refrigerator & Freezer Repair)
by rcn01 9/12/2021 12:26:48 PM(UTC)
Ice Maker Issues (Whirlpool WRF736SDAM14) (Refrigerator & Freezer Repair)
by aarondahmen 5/1/2020 1:02:37 PM(UTC)
Kitchenaide side by side Ice Maker issues (Refrigerator & Freezer Repair)
by Dedalus 2/27/2018 5:43:35 PM(UTC)
Ice maker issues (Refrigerator & Freezer Repair)
by swoldhagen 1/21/2013 5:34:48 PM(UTC)
ice maker issues (Refrigerator & Freezer Repair)
by shawk468 12/16/2012 3:52:06 PM(UTC)
by smhlbailey@hotmail.com 8/12/2012 5:10:29 PM(UTC)
KitchenAid Refrigerator Ice Maker Issues (Refrigerator & Freezer Repair)
by KitchenAid-Sucks 4/19/2012 3:30:33 PM(UTC)
by diggo 1/7/2012 7:00:24 AM(UTC)
by scottwalter 12/4/2011 11:01:57 AM(UTC)
Samsung Ice maker issues (Refrigerator & Freezer Repair)
by danlee 9/24/2011 12:15:25 PM(UTC)
by pe34 3/29/2011 6:19:44 AM(UTC)
