chuck.oliveira
#1 Posted : Monday, October 19, 2009 3:54:35 PM(UTC)
chuck.oliveira
I am trying to remove the dryer motor. I removed one screw holding it to the bottom panel. I removed the clip holding the motor to the bulkhead. It seems the motor shaft is press fit to the blower peice.
How do I detach the motor?
ANy help is greatly appreciated.
Chuck
#2 Posted : Tuesday, October 20, 2009 2:08:46 AM(UTC)
Replacement parts for WHIRLPOOL LER4634EQ2 | AppliancePartsPros.com
The blower wheel is threaded onto the motor's shaft.
Note that it is left hand thread, also some of them are very stubborn and you end up breaking them.
Below is removal info, sometimes you have to use vice grips to hold the shaft.
http://www.applianceaid.com/wp-motors.html
how to remove motor pulley? (Washer Repair)
by turchekj 8/11/2010 8:46:02 AM(UTC)
How to Remove Motor Pulley? (Washer Repair)
by dawabu 6/24/2010 2:59:24 PM(UTC)
how to remove Motor from Whirlpool (Dishwasher Repair)
by tomlicnk 4/2/2009 9:18:14 AM(UTC)
