AppliancePartsPros.com
Appliance Repair Help
18 year old GE element went white hot after oven was turned off. Had to pull plug to
18 year old GE element went white hot after oven was turned off. Had to pull plug to shut it down. Is there a contactor in the temperature controller that may have welded together?
I cannot find any info on the given model number.
I am assuming that the entire element went very hot and not just part of it.
The elements are usually controlled by relays that are on the control board/timer. |
THIS FORUM IS DEAD!!!!!!! |
