gp3002
#1 Posted : Monday, October 19, 2009 8:22:52 AM(UTC)
gp3002
I found my couplers are broken but also noticed oil leaking from my machine . it apeears to be from the bottom. Do I need to replace the clutch or transmission?
sidfink43
#2 Posted : Tuesday, October 20, 2009 3:19:27 PM(UTC)
sidfink43
The only oil in this machine is inside the transmission case, so that is where you have the problem. It is possible the transmission lost oil and jammed and caused the coupling to break.
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
Oil leaking in GE Washer (Washer Repair)
by smorberg 9/28/2014 8:48:35 AM(UTC)
Oil Leaking On Clothes!! (Washer Repair)
by ladyfixer 2/15/2011 2:00:07 PM(UTC)
oil leaking on floor (Washer Repair)
by gcm 4/27/2010 4:25:45 AM(UTC)
Oil Leaking into the basket (Washer Repair)
by Ruben1977 4/3/2010 4:29:27 PM(UTC)
oil leaking into drum (Washer Repair)
by DaronDavis 4/17/2008 7:54:09 PM(UTC)
