djs1614
#1 Posted : Friday, March 7, 2014 9:44:08 AM(UTC)
djs1614
I have a whirlpool cooktop ( gas ) model SCS3014GB2 wishing to convert it to (LP), and be able to use as a outside appliance using my 20/30 lb propane tank. I understand i have to change the orifice on the burners, I have those, my issue is- do i need to replace the push valve on the regulator which is on the stovetop with one for LP, the other issue connecting the lp tank to the stove top.
Remove bosh burners from cooktop (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/8/2024 9:58:44 PM(UTC)
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Induction cooktop EHI965BA error E9 (Oven Repair (including Ranges and Cooktops))
by Guest 11/28/2023 8:00:28 PM(UTC)
Bosch Induction Cooktop NIT3065/UC Non-Responsive (Oven Repair (including Ranges and Cooktops))
by trishglxk 10/3/2023 9:18:30 AM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
How to remove the sticky screws in GE cooktop? (Oven Repair (including Ranges and Cooktops))
by Guest 4/9/2023 10:34:15 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Frigidaire FEF369CGSB - Strange Cooktop Behavior (Oven Repair (including Ranges and Cooktops))
by trymes 3/22/2023 5:59:36 PM(UTC)
Kitchen aid/whirlpool Induction Cooktop Fuses (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 8:42:15 AM(UTC)
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 11/20/2022 6:48:33 PM(UTC)
Heartland cooktop elements (Appliance Parts)
by Guest 10/11/2022 11:30:11 AM(UTC)
Installing Frigidaire FGGC3047QS Gas Cooktop (Oven Repair (including Ranges and Cooktops))
by Samkat923 8/2/2022 7:26:14 AM(UTC)
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3/26/2022 5:48:44 AM(UTC)
Cooktop anamoly (Oven Repair (including Ranges and Cooktops))
by RodB 2/17/2022 2:08:20 PM(UTC)
KitchenAid Gas Cooktop Solenoid Diagnosis (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 1/17/2022 9:09:30 AM(UTC)
