djs1614
#1 Posted : 11 years ago
djs1614
You have been a member since:: 3/7/2014(UTC)
Views messages in topic : 1
I have a whirlpool cooktop ( gas ) model SCS3014GB2 wishing to convert it to (LP), and be able to use as a outside appliance using my 20/30 lb propane tank. I understand i have to change the orifice on the burners, I have those, my issue is- do i need to replace the push valve on the regulator which is on the stovetop with one for LP, the other issue connecting the lp tank to the stove top.
Remove bosh burners from cooktop (Oven Repair (including Ranges and Cooktops))
by stevekauss 12 months ago
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds about a year ago
Induction cooktop EHI965BA error E9 (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
Bosch Induction Cooktop NIT3065/UC Non-Responsive (Oven Repair (including Ranges and Cooktops))
by trishglxk 2 years ago
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 2 years ago
How to remove the sticky screws in GE cooktop? (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 2 years ago
Frigidaire FEF369CGSB - Strange Cooktop Behavior (Oven Repair (including Ranges and Cooktops))
by trymes 2 years ago
Kitchen aid/whirlpool Induction Cooktop Fuses (Oven Repair (including Ranges and Cooktops))
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 2 years ago
Heartland cooktop elements (Appliance Parts)
Installing Frigidaire FGGC3047QS Gas Cooktop (Oven Repair (including Ranges and Cooktops))
by Samkat923 3 years ago
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3 years ago
Cooktop anamoly (Oven Repair (including Ranges and Cooktops))
by RodB 3 years ago
KitchenAid Gas Cooktop Solenoid Diagnosis (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 3 years ago
