The clothes are noticeably wetter than previously after spin cycle but not “wringing wet.” From seeing earlier advice the clutch may be the issue. I have a tachometer – does anyone know the proper tub rotating speed so I can measure whether tub is rotating more slowly during spin cycle? Thanks.
Groups: Expert
640-650rpm in high speed.
Eric
Thanks Eric - I'll check out the rotating speed under different conditions and see what is going on.
Rotating at 380 rpm with tub empty. Next step is to check out clutch. Thanks again Eric.
