HankMcDermott
#1 Posted : Monday, March 3, 2014 9:40:25 AM(UTC)
HankMcDermott
The clothes are noticeably wetter than previously after spin cycle but not “wringing wet.” From seeing earlier advice the clutch may be the issue. I have a tachometer – does anyone know the proper tub rotating speed so I can measure whether tub is rotating more slowly during spin cycle? Thanks.
fairbank56
#2 Posted : Monday, March 3, 2014 12:40:05 PM(UTC)
fairbank56
Groups: Expert
640-650rpm in high speed.
Eric
HankMcDermott
#3 Posted : Monday, March 3, 2014 9:35:50 PM(UTC)
HankMcDermott
Thanks Eric - I'll check out the rotating speed under different conditions and see what is going on.
HankMcDermott
#4 Posted : Tuesday, March 4, 2014 8:59:35 AM(UTC)
HankMcDermott
Rotating at 380 rpm with tub empty. Next step is to check out clutch. Thanks again Eric.
