witsend
#1 Posted : Monday, February 11, 2008 5:50:29 AM(UTC)
witsend
Igniter lights, burner ignites but burner only stays on momentarily.
Other times burner may stay lit for several minutes, and yet on other occasions: no igniter, no burner. Attempted to remove igniter to check continuity and it fell apart in my hand, replaced with new igniter. Igniter works fine now, but still sporadic operation. Checked continuity on 3 thermostats , all were ok. How can I determine if its cycling at the proper temperature? My gut says high limit...but what do I know.
Thanks for your help.
#2 Posted : Monday, February 11, 2008 3:01:18 PM(UTC)
There are two parts which could cause such problem: the flame sensor (heat detector) and the gas valve coils.
I would start with the flame sensor.
- The part number for the flame sensor is AP2042635
- The part number for the set of coils is AP2150379
witsend
#3 Posted : Monday, February 11, 2008 7:28:55 PM(UTC)
witsend
Thanks a lot for the info. In my previous post, I forgot to mention that I had checked the flame detector continuity as okay. Is it possible that flame detector could be bad even with a good continuity reading? It makes sense to start with the cheapest first, so I just ordered the coils. I'll let you know how I make out.
#4 Posted : Monday, February 11, 2008 9:31:22 PM(UTC)
It does not happened very often but it could be an intermittent problem with the flame detector.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Gas dryer problem, GGW9250PW service manual needed (Dryer Repair)
by ergmeister 5/11/2012 11:52:27 AM(UTC)
Gas Dryer problem (low/no Heat) (Dryer Repair)
Belarus rkurelowech 9/14/2010 9:15:16 AM(UTC)
maytag bravo gas dryer problem (Dryer Repair)
by bugjuice 7/14/2010 10:26:02 AM(UTC)
GE gas dryer problem (Dryer Repair)
by joe75 11/30/2007 4:24:28 PM(UTC)
GAS Dryer Problem (Dryer Repair)
by Miss 10/22/2007 4:38:13 PM(UTC)
