My nearly new electric dryer is stopping halfway through the cycle and popping open the door like the clothes are done but they are damp. I have cleared all the vents and the fan of lint (there was very little) and was still having the issue. I tested both thermostats in the drum and they both work I have also tested the thermostat by the lint trap which also works. Both thermisters are showing 90ohms at room temp and decrease when heated. I have no idea what the problem is, any help would be greatly appreciated!
Here are your parts. Parts for GE GFDN240EL1WW / - AppliancePartsPros.comCould be that the door is not latching correctly/tight enough. The clothes then pop the door open stopping the unit. Check the door strike (item 3049 in section 02) and the door latch (item 327 in section 03). |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the reply, the door defenatly feels like it comes open easier than it should. I wonder if one of my kids was hanging on it. Also I ran the codes and got error code 11 dryer motor or centrafugal sensor error. Would that be causing the problem, the dryer does not over heat.
I do not have access to GHE tech data so I cannot say what that error actually means.
Run a cycle with no clothes in the unit to see if it runs OK.
If it runs OK then I would prop something against the door so it cannot open and run a cycle with clothes in it. If that also runs OK then I would say that the latch parts need replacing.
If the female part of the latch is OK sometimes you can bend the male part out a bit (make it wider where the latch catches) with needle nose pliers. |
