TOMZYBKO
#1 Posted : Sunday, February 10, 2008 2:25:00 PM(UTC)
TOMZYBKO
Every 1minute And 30 Seconds Freezer Cycles For 4 Seconds And Lighs Dim ,
kooler
#2 Posted : Monday, February 11, 2008 10:41:52 AM(UTC)
kooler
You either have a defective start relay which is an inexpensive part or a defective compressor which is expensive... Jot down the model number of your gibson and input it to the APPros parts site to identify and acquire a new start relay... If your compressor starts after replacing the relay then you may be in the clear and have your refrigerator back to normal.. Otherwise if the symptoms persist then most likely your compressor is bad... The decision to replace the compressor or the refrigerator is your next step... good luck, kooler
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 6/5/2024 12:10:09 PM(UTC)
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 5/14/2024 3:39:48 PM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
