alan2112drums
#1 Posted : Thursday, February 6, 2014 6:54:18 AM(UTC)
alan2112drums
The door on this oven will not open more than 2 inches. I believe the issue is with the hinges and not the lock mechanism. I tried the self clean trick and the lock opened, so that is not the problem. Perhaps a lock mechanism on the hinge has engaged preventing the door from opening? If anyone has a solution to removing the door in this condition, I would greatly appreciate your insight.
Thanks,
Alan
alan2112drums
#2 Posted : Thursday, February 6, 2014 6:11:51 PM(UTC)
alan2112drums
I managed to remove the door panel so I can see the part of the hinge with the spring at the top but I can't manipulate it in any way. Is there anything I can do to remove the door now?
Viking Oven Door Won't Open (Oven Repair (including Ranges and Cooktops))
by steve aibel 1/9/2014 9:38:36 AM(UTC)
Oven door won't open fully on GE slide-in oven JSP38GV1BB (Oven Repair (including Ranges and Cooktops))
Belarus Al Thumbs 2/11/2013 9:49:38 AM(UTC)
Maytag Double Oven door won't open (lock) (Oven Repair (including Ranges and Cooktops))
by tincup731 3/13/2011 5:29:06 AM(UTC)
Oven door won't open (Oven Repair (including Ranges and Cooktops))
by lgarlock 1/13/2009 12:01:58 PM(UTC)
by larrym1112 9/24/2008 3:16:41 PM(UTC)
