russell@txwrights.com
#1 Posted : Monday, January 20, 2014 5:49:09 PM(UTC)
Removed back panel in freezer and found large ice buildup on the defrost thermostat. [IMG]https://skydrive.live.com/redir?resid=5B0F4CB27B0CB47A%2110877[/IMG]
Ideas on cause?
Otherwise the evaporator looks clear.
#2 Posted : Wednesday, January 22, 2014 2:52:41 AM(UTC)
If evaporator only has a small area of frost, you have a bad compressor/refrigerant leak.
#3 Posted : Wednesday, January 22, 2014 5:11:50 AM(UTC)
Yup, that is the symptom. Frost at the bottom and top of the evaporator and clear all over. Could it be a compressor relay or start capacitor? I ran the service diagnostics and the thermistor, heating element and fans checked out. I'm with you though, a weak charge or bad compression could be the issue.
Is there a good way to test the compressor or charge besides removing it?
Thanks for the help.
#4 Posted : Thursday, January 23, 2014 12:38:35 AM(UTC)
Best to buy a new fridg.
