SakmanMario
#1 Posted : Monday, January 20, 2014 7:56:40 AM(UTC)
SakmanMario
I have a side by side freezer-refrigerator. Both side not cold enough. I set at 0 deg on freezer and 35 deg on ref rig side but temp above that even after 24 hrs. compressor hot. fan running. no ice. H2O dispenser outputs lukewarm water. I note that the coil panel in the freezer side is building up with frost. Is this frost normal? I need help troubleshooting this. Thanks.
Fridge not cooling. No frost on coils. (Refrigerator & Freezer Repair)
by miketh2005 2/20/2017 3:24:09 PM(UTC)
Freezer not freezing & Fridge not cooling like they should Frost on Coils (Refrigerator & Freezer Repair)
by tnhottie025 12/3/2014 6:43:22 AM(UTC)
Freezer OK, Fridge Not Cooling, But No Frost on Coils, more (Refrigerator & Freezer Repair)
by maudie 7/31/2014 12:36:44 PM(UTC)
GE Freezer and refrigerator warm, frost on coils-what should an amateur change first? (Refrigerator & Freezer Repair)
by dfavelo 10/2/2013 6:55:19 PM(UTC)
No frost on coils (Refrigerator & Freezer Repair)
by Teal1 10/4/2012 10:40:17 AM(UTC)
by Sean C 7/19/2009 9:31:12 AM(UTC)
