cdnhawk02
#1 Posted : Friday, January 17, 2014 3:19:11 PM(UTC)
cdnhawk02
Model D7003KW419
Serial HF586334
GE Stackable
Hello all,
Desperately need your help once again. Discovered a small crack in the tub seal of a stackable washer/dryer combo that my mother owns.
I have been reading through the forums and cannot find the details i require to take this stackable washer apart.
I have been able to remove the front covers with no issues. Can visually see a small crack in the tub seal. The part number WH08X10004 seems VERY expensive, which i believe is associated to the GE naming convention :)
Does Frigidaire make a cheaper version of the same part?
Does anyone have any specific manuals or breakdowns of how to remove the washer tub assembly? I have only found the standard removal procedure for stand alone machines. Just need to gauge if this job is going to be a two day or one day.
Much appreciate all your help in advance. God i love this forum, it has saved me thousands of dollars at the very least.
Cheers,
Jason
sidfink43
#2 Posted : Sunday, January 19, 2014 3:33:10 PM(UTC)
sidfink43
I am not getting your model number to come up, but if this is the basic Frigidaire stacked unit, here is a link to a service manual.
http://www.emaservicetips.com/pdfs/488_3.pdf
You may well be able to use a Frigidaire labeled part, check with APP on Monday and see if they can help you.
