AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE (frigidaire) Stackable Washer/Dryer Tub Seal Leak! Help Pls!
Model D7003KW419 Serial HF586334 GE Stackable
Hello all,
Desperately need your help once again. Discovered a small crack in the tub seal of a stackable washer/dryer combo that my mother owns.
I have been reading through the forums and cannot find the details i require to take this stackable washer apart.
I have been able to remove the front covers with no issues. Can visually see a small crack in the tub seal. The part number WH08X10004 seems VERY expensive, which i believe is associated to the GE naming convention :)
Does Frigidaire make a cheaper version of the same part?
Does anyone have any specific manuals or breakdowns of how to remove the washer tub assembly? I have only found the standard removal procedure for stand alone machines. Just need to gauge if this job is going to be a two day or one day.
Much appreciate all your help in advance. God i love this forum, it has saved me thousands of dollars at the very least.
Cheers,
Jason
I am not getting your model number to come up, but if this is the basic Frigidaire stacked unit, here is a link to a service manual. http://www.emaservicetips.com/pdfs/488_3.pdfYou may well be able to use a Frigidaire labeled part, check with APP on Monday and see if they can help you.
Washer Repair
