minvac
#1 Posted : Wednesday, January 15, 2014 9:28:26 AM(UTC)
minvac
SYMPTOMS:
- intermittent buzzing noise from compressor; gradually gets worse
- 2 or 3 times freezer/fridge stopped cooling and got warm
- freezer frosted over behind panel (frost over coils)
TESTING/REPAIRS:
- All diagnostics from the control panel buttons passed - defrost circuit result of "shorted" (closed) which apparently is a good thing?
- Tested heating element with multimeter, still good
- Melted the ice and replaced the defrost thermostat with a new one
RESULTS:
- Compressor still buzzing, incrementally worse
- Freezer not frosting up behind panel yet but freezer and fridge still very cold (or if compressor buzzes a lot and runs hot, stop cooling)
QUESTIONS:
- Is this likely cause the defrost timer on the control (jazz) board, even though all the control diagnostics seem to pass?
- Would the buzzing in the compressor be caused by a problem with the control, or is it likely the compressor is going bad?
I've been trying to post, fix myself and study answers on here for past 3 months - not sure whether to throw in the towel and get a new fridge or try anything else. Help appreciated!!!!
:confused: Thank you for your time. - Mindy
#2 Posted : Thursday, January 16, 2014 1:19:15 AM(UTC)
You have a hard starting compressor, probably starts better during low power use periods.
minvac
#3 Posted : Thursday, January 16, 2014 6:34:07 AM(UTC)
minvac
Thank you for your response. Would you recommend that I try replacing the overload relay/starting device?
#4 Posted : Thursday, January 16, 2014 7:36:17 AM(UTC)
It's possible you have a burnt wire someplace, or a weak klixon. You can try one and check for a burnt wire.
