Washer gives e47 code in diagnostic mode. Pulled door latch assy. and tested ptc terminals and it checked about 3k ohms. Is this ok? Or should it be closer to 1500 ohms. If it is ok what should I check next.
I cannot find any info on the given model number tried here and the Frigidaire site. Also if I Google it all that came up was your post.
Please check it.
Note that if this is not a North American unit info may not be available. |
THIS FORUM IS DEAD!!!!!!! |
Do new lock assy. ptc resistance measuer 1500 ohms or more.
