How do I set the freezer and refriderator to the correct temprature?
Cannot say without a model number. Find your model number - AppliancePartsPros.comOnce you have a model number you can go the GE appliances website and probably download the manual. The freezer should be between 0 and 5 degrees F and the fresh food at just below 40 degrees. if the unit has an ice maker keep the freezer closer to o degrees as the freezer temperature effects ice production. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for responding. Its a GE Monogram ZFSB26DNA SS. The temprature won't keep consistent temprature. The freezer is 47 and the fridge is 58. I unplugged the unit to try and reset. Nothing is workin.
By "nothing is working" do you mean that both fans and the compressor is off? Also are the temperature displays blank? I cannot find any info on this specific model but below is a manual that will at least let you see how GE does things. http://appliancejunk.com...&id=316;t=1389605564You will have to join the site and be logged in to be able to download the manual. |
The fans and compressor are working. The temprature pad shows a readout it just wont allow me to change the temprature.
Could be the main control board or the keypad itself. Depends on whether this unit has separate control and keypad.
Have you tried unplugging the unit for a couple minutes to see if it will reset? |
