rdelarosa1
#1 Posted : Friday, January 10, 2014 11:46:39 AM(UTC)
rdelarosa1
How do I set the freezer and refriderator to the correct temprature?
#2 Posted : Sunday, January 12, 2014 3:29:13 AM(UTC)
Cannot say without a model number.
Find your model number - AppliancePartsPros.com
Once you have a model number you can go the GE appliances website and probably download the manual.
The freezer should be between 0 and 5 degrees F and the fresh food at just below 40 degrees.
if the unit has an ice maker keep the freezer closer to o degrees as the freezer temperature effects ice production.
rdelarosa1
#3 Posted : Sunday, January 12, 2014 5:47:56 PM(UTC)
rdelarosa1
Thanks for responding. Its a GE Monogram ZFSB26DNA SS. The temprature won't keep consistent temprature. The freezer is 47 and the fridge is 58. I unplugged the unit to try and reset. Nothing is workin.
#4 Posted : Monday, January 13, 2014 12:35:19 AM(UTC)
By "nothing is working" do you mean that both fans and the compressor is off?
Also are the temperature displays blank?
I cannot find any info on this specific model but below is a manual that will at least let you see how GE does things.
http://appliancejunk.com...&id=316;t=1389605564
You will have to join the site and be logged in to be able to download the manual.
rdelarosa1
#5 Posted : Monday, January 13, 2014 9:07:40 AM(UTC)
rdelarosa1
The fans and compressor are working. The temprature pad shows a readout it just wont allow me to change the temprature.
#6 Posted : Tuesday, January 14, 2014 12:15:55 AM(UTC)
Could be the main control board or the keypad itself.
Depends on whether this unit has separate control and keypad.
Have you tried unplugging the unit for a couple minutes to see if it will reset?
