mtnmanst
#1 Posted : Monday, January 6, 2014 3:26:02 PM(UTC)
mtnmanst
my dryer will not shut off the drum spins continually the only way to stop it is to turn the beaker off and when u turn the beaker on the drum spins even when the door is open and no heat can you help.
#2 Posted : Tuesday, January 7, 2014 12:57:20 AM(UTC)
Parts for SE1000 - AppliancePartsPros.com
Here is a service manual
http://appliancejunk.com...e&id=68;t=1389087162
You will have to join the site and be logged in to download the manual.
I would start by looking at the motor relay.
Unplug the unit and check across the relay contacts with a meter.
If they are 0 ohms then the relay contacts are welded together.
If open (infinite ohms) then odds are that the control board is bad.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
mtnmanst
#3 Posted : Tuesday, January 7, 2014 6:26:05 AM(UTC)
mtnmanst
That was the conclusion that I came to about15 minutes after I posted ty for the help
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Nursing Paper Review SOS: Help a Peer Out! (General Talk)
by Guest 6/19/2024 3:00:02 AM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
