please help! i have GE Profile Harmony Gas Dryer DPGT750GC, and it just stoped drying the cloths, the drum is turning but no hit, it does not hit any more. please advise how to repair it!
Unplug the dryer and remove it to the yard if possible. Start here Older models need to have this clip removed(yer we3x75 goes there) we3x75 drum bearing Note: dryer squeaks when this dude gets thin That squeak....squeak...squeak thing is this bearing going out. Remove the screws:
Lift the front out yer way Bad drum glides(red arrows) make weird noises sorta like bad rear brake shoes on a garbage truck or bus; the plastic slides and the bearing itself will wear out and the drum will hit the dryer door housing and eat down into it. Seen it. Old style drum glide. Note: Makes a scrubbing metal to metal noise when the plastic has disentergrated. Inside the dryer: Note location of non-resetible limit (if bad dryer will not run)
A broken heating element: Broken dryer element (can easily be restrung)No need to buy the whole new pan!
