mikadze
#1 Posted : Friday, October 16, 2009 11:10:06 AM(UTC)
mikadze
please help! i have GE Profile Harmony Gas Dryer DPGT750GC, and it just stoped drying the cloths, the drum is turning but no hit, it does not hit any more. please advise how to repair it!
SublimeMasterJW
#2 Posted : Friday, October 16, 2009 11:19:35 AM(UTC)
SublimeMasterJW
Unplug the dryer and remove it to the yard if possible.
UserPostedImage
Start here
UserPostedImage
Older models need to have this clip removed(yer we3x75 goes there)
UserPostedImage
we3x75 drum bearing Note: dryer squeaks when this dude gets thin
That squeak....squeak...squeak thing is this bearing going out.
Remove the screws:
UserPostedImage
Lift the front out yer way
UserPostedImage
Bad drum glides(red arrows) make weird noises sorta like bad rear brake shoes on a garbage truck or bus; the plastic
slides and the bearing itself will wear out and the drum will hit the dryer door housing and eat down into it. Seen it.
UserPostedImage
Old style drum glide. Note: Makes a scrubbing metal to metal noise when the plastic has disentergrated.
UserPostedImage
Inside the dryer:
UserPostedImage
Note location of non-resetible limit (if bad dryer will not run)
A broken heating element:
UserPostedImage
Broken dryer element (can easily be restrung)No need to buy the whole new pan!
UserPostedImage
A good look at how dat belt oughta be if installed all propah.
GE Harmony Dryer Manual :D
