kprovost10
#1 Posted : Saturday, January 4, 2014 4:47:48 PM(UTC)
kprovost10
I'm attempting to repair a Whirpool LEW 0050pq that had no power. The heating element had a broken coil so I replaced it, still nothing. I know there are 2 other thermostats not with the element. Safety and another. Would these need to be replaced as well? I know the drum needs to be removed for that but didn't want to do that if it is not likely to be the issue.
Thanks!
#2 Posted : Tuesday, January 7, 2014 1:50:19 AM(UTC)
Parts for LEW0050PQ - AppliancePartsPros.com
You seem to be missing the last digit of the model number so you will have to choose one from the Matching Model Numbers section.
The first this to check when there is no heat is the power to the unit.
Usually the heating coil requires the full 240 volts and everything else runs off of 120 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
I cannot find any tech info (wiring diagram etc.) for this unit so must generalize on it.
There are 4 thermostats in the unit.
Items 48 and 49 in section 01 on the heater
items 3 and 4 in section 03 on the blower.
Looks like item 49 is resettable as it has a red button on the back.
48 may also be resettable but it is hard to tell from the pictures of it.
All thermostats should be 0 ohms at room temperature.
unforetunately they call every item a thermostat so I can can just give you info on how most dryers are wired.
On the blower:
One is the operating thermostat which controls the temperature.
The other is a thermal fuse which opens if it gets too hot. Usually this kills power to the motor and is caused by a dirty vent system.
On the heater:
One is a hi-limit thermostat. It opens when there is an overheat condition in the heater. It resets once the heater cools down.
The other is a thermal cut-off. It opens at a higher temperature than the hi-limit and does not reset. It is an extra safety device because the hi-limit's contacts are not made to continually open/close so eventually weld together.
The most common cause of the cutoff blowing is a grounded element so it must be checked if the cutoff is open.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
fairbank56
#3 Posted : Tuesday, January 7, 2014 4:13:23 AM(UTC)
fairbank56
Groups: Expert
