Relay and overload protector are no longer available for my fridge So I'm forced to replacing it with a 3 n 1 start RC0410 not sure on the Wiring I know we're the red,white & blk wires go but not sure of the other 2 black wires go
Do NOT use the 3 n 1, it will blow out your compressor. If you have a square, black item connected to two compressor terminals, that is the ptc start device. You need to make ohm meter measurements on it so I can help you. Also, it would help to state your problem.
Fridge was not staying cold compressor was not starting I took out the relay and shook it and it sounded like everything was broken inside. Yes the relay has 2 wires a pink one and a blue one and the overload protector has a black wire I checked the compressor with an ohm and it was fine
![ScreenHunter_143 Nov. 22 20.04.jpg ScreenHunter_143 Nov. 22 20.04.jpg](/resource.ashx?p=6733&b=1) This is what I have Carreiro attached the following image(s):
Make a diagram of the wires to the brown start device and order a new one.
