Nelsen
#1 Posted : Monday, December 30, 2013 11:25:23 AM(UTC)
Nelsen
I have a older magic chef refrigerator/freezer which stopped cooling. It is making a clicking noise at the compressor. I replaced the capacitor which did not fix the problem. I did not replace the overload switch. I tested the terminals for resistance and there was continuance from each terminal to the other 2. No ground continuance demonstrated. Values from two of the terminals was 10 and 9 on the compressor. The last two terminals gave a zero value, however the circuit was closed as the multimeter sound was demonstrated. Thoughts?
#2 Posted : Tuesday, December 31, 2013 3:04:46 AM(UTC)
Look at the nameplate, does it have R 12 refrigerant?
Nelsen
#3 Posted : Monday, January 20, 2014 8:49:53 AM(UTC)
Nelsen
Magic Chef uses R12 refrigerant
#4 Posted : Tuesday, January 21, 2014 12:32:31 AM(UTC)
Try a new start ptc device available on this site.
Nelsen
#5 Posted : Tuesday, January 21, 2014 3:48:56 AM(UTC)
Nelsen
what about the overload which i did not replace? The start capacitor I did replace. Are you thinking it may be bad?
#6 Posted : Tuesday, January 21, 2014 4:55:03 AM(UTC)
It seems like your overload is ok, but if you can get one, replace it. All indications are your start device is blown open.
Nelsen
#7 Posted : Tuesday, January 21, 2014 5:20:22 AM(UTC)
Nelsen
Ok i will replace the start capacitor a second time. When i looked up overload switch on this site for parts they had two different switches with no picture of overload? Which should I get for this model?
#8 Posted : Tuesday, January 21, 2014 3:17:24 PM(UTC)
Either overload should work if they are for your fridg. The capacitor is a run capacitor, they very rarely fail, you need to replace the start device.
