lauren110288
#1 Posted: : Tuesday, December 24, 2013 7:34:38 AM(UTC)
lauren110288
Had to move stove to install new microwave above. Moved stove back and now stove turns on (clock/lights/etc. all work), but the only eye that gets hot is the "warming zone" Oven also does to get warm. Tried flipping the breaker at the fuse box, no change! Any idea what it could be?? Thanks!
#2 Posted : Wednesday, December 25, 2013 2:45:58 AM(UTC)
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316519914.pdf
Sounds like you lost the 240 volts.
Check the power at the wall receptacle.
If OK check it at the terminal strip in the unit.
Be very careful as 240 volts is lethal.
L1 to Neutral should be 120 volts.
L2 to Neutral should be 120 volts
L1 to L2 should be 240 volts.
