All Wet
#1 Posted : Sunday, December 22, 2013 8:46:43 AM(UTC)
All Wet
Bought Dec.16,2013. 1 1/2 weeks ago. Bought at sears off display floor, brand new. Brought home next day and installed. While installing, water was heard sloshing around inside washer. Is this normal for a brand new wash machine? Sears says it's from the factory, left there after they tested it. I find this hard to believe and think they sold me a used machine. Also, the owners manual packet had been torn open. Also, the zip tie that holds the drain in place looked used. Opinions?
fairbank56
#2 Posted : Sunday, December 22, 2013 9:42:02 AM(UTC)
fairbank56
Groups: Expert
You were probably hearing fluid in the tub balance ring which is normal. What is the serial number of the washer? With that, I can give date of manufacture.
Eric
All Wet
#3 Posted : Sunday, December 22, 2013 10:00:42 AM(UTC)
All Wet
C32032170 is the serial # I believe
fairbank56
#4 Posted : Sunday, December 22, 2013 10:34:40 AM(UTC)
fairbank56
Groups: Expert
Looks like August of 2012. Serial numbers usually start with two letters though.
Eric
