Haven't been able to change run cycles since almost new, but ignored problem because the washer did what I wanted (run regular cycle.) Recently it wouldn't complete cycle, (would run for hours until I shut it off) so bought new control module. Removed facia, and wallah!...all the little plastic actuator links behind the cycle buttons on the old module were broken. Hope replacement fixes cycle control. But when I took the door panel off, two identical plastic pieces fell out. Each is black, about 1.5" in each dimension, roughly "U" shaped. They have 6 comb-looking prongs that stand up on one side. Can't see any obvious place where they go. Are they important? Any hints on what to do with them?
