Greg L
#1 Posted : Wednesday, October 14, 2009 2:41:10 PM(UTC)
Greg L
want to find out what the F7 error code is and how to fix it?
#2 Posted : Wednesday, October 14, 2009 4:40:35 PM(UTC)
This problem most likely connected to the control panel ribbon cable and has nothing to do with the ERC relays.
Open the control panel, unplug the ribbon cable from the control board and clean the contacts with a pencil eraser. Check the tracks in the ribbon cable for a hairline cracks, using a magnifier. Reconnect everything and give it a try.
If it would not help then replace the control panel. If you need the correct part number then post the color of the control panel.
amana nfw7300 error code f7e1? (Washer Repair)
by garybelmer 12/5/2011 2:16:04 PM(UTC)
Whirlpool Duet Dryer and Error Code F70 (Dryer Repair)
by bustdwhrpl 10/6/2011 5:55:34 PM(UTC)
error code F7 on oven (Oven Repair (including Ranges and Cooktops))
by TessaRae311 6/15/2011 7:04:30 PM(UTC)
frigidaire oven problem. Error Code f7 (Oven Repair (including Ranges and Cooktops))
by elachastain 9/30/2010 2:33:43 PM(UTC)
Kenmore dryer error code F70 (Dryer Repair)
by ls007 10/1/2009 6:03:12 PM(UTC)
2001 GE single oven - error code F7 (Oven Repair (including Ranges and Cooktops))
by buxtonl 12/1/2008 9:54:17 AM(UTC)
2002 KitchenAid error code F7:EO (Oven Repair (including Ranges and Cooktops))
by RWR 12/12/2007 11:04:18 AM(UTC)
