vp02031958
#1 Posted : Wednesday, October 14, 2009 1:06:16 PM(UTC)
vp02031958
I have replaced the control board and the wax motor..my clothes still come out dripping wet...I have examined the lower control board...it looks fine...no burn areas....I have now removed the 'spin switch' located in the upper area next to the wax motor...wondering if this could be my problem.. anything else to check before I am forced to purchase a lower control board for $220??
thx
sidfink43
#2 Posted : Thursday, October 15, 2009 4:11:38 PM(UTC)
sidfink43
I am not sure which part you are refering to, but you can check the board using the procedures in the service manual. Here it is.
http://www.servicematters.com/m...ibrary/docs/16010061.pdf
Here is the Maytag tech bulletin on the replacement motor/motor control board package you will need if the board is bad.
http://www.servicematters.com/m...rary/docs/TDL-0018-B.pdf
and here is the part if you need it, a little less expensive than you have in your post, but unfortunately still a pretty big cost.
Part number: AP4010145
Spin Switch broken off (Washer Repair)
by LindaPatricia 7/2/2015 6:11:32 AM(UTC)
