flaumbetty
#1 Posted : Thursday, August 9, 2007 7:21:38 PM(UTC)
flaumbetty
The front left burner of my Magic Chef won't ignite. The gas does get through, you can hear and smell it but the igniter/flame never catches.
I've lifted the stove lid but i don't know what part i need to replace as it looks like both burners are on the same igniter.
Thanks.
Admin / APP Team
#2 Posted : Thursday, August 9, 2007 8:28:21 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
I'd say the burner switch is bad. Each valve has a switch sitting right on it, behind the knob. When you turn the knob, it activates the switch which sends the signal through the spark module to the igniter. There is a small chance that the module itself is bad, but most likely it's the switch.
Your model calls for a couple of different spark switches. The way to find the right switch is by using the serial number. If you post your serial number here, I'll tell you which switch is the right one for your stove. The serial number can be found on the same tag as the model number. Alternatively, you can post all the numbers off the old switch and I can find it that way.
flaumbetty
#3 Posted : Friday, August 10, 2007 6:19:27 PM(UTC)
flaumbetty
Okay its a Magic Chef range
serial # 35C 942954230
Model # 3IHA- 92KX
Admin / APP Team
#4 Posted : Saturday, August 11, 2007 3:38:01 PM(UTC)
Admin / APP Team
Groups:
Thanks,
It's not very clear which one of these two switches is the right one for your model, so please look at both photos to confirm:
- First choice
- Second choice
dodgeguy
#5 Posted : Friday, January 25, 2008 12:14:01 AM(UTC)
dodgeguy
I have had this problem with my magic chef a few times. 2 burners will work fine and 2 will not light. it is always the spark module. i just ordered my 3rd module today. with luck this one will last more than a few years
kawfeeman
#6 Posted : Friday, January 25, 2008 4:39:47 AM(UTC)
kawfeeman
make sure polarity is correct in your outlet ...
Viking VDSC365 Grill Burner won't ignite (Oven Repair (including Ranges and Cooktops))
by hippiasrex 8/30/2021 11:08:29 AM(UTC)
Troubleshooting single burner won't ignite. (Oven Repair (including Ranges and Cooktops))
by mingd 6/28/2017 1:36:23 AM(UTC)
Extra Low Burner won't ignite not the Potentiometer (Oven Repair (including Ranges and Cooktops))
by pcl1194 12/12/2014 1:52:17 PM(UTC)
Range Burner Won't Ignite (Oven Repair (including Ranges and Cooktops))
by Boatman12 4/11/2013 11:58:00 AM(UTC)
Whirlpool Gas Oven burner won't ignite (Oven Repair (including Ranges and Cooktops))
by dmargosh 12/1/2012 8:09:54 AM(UTC)
kichenaid oven lower burner won't ignite (Oven Repair (including Ranges and Cooktops))
by steinmej 8/4/2012 9:31:43 AM(UTC)
Thermador gas burner won't ignite (Oven Repair (including Ranges and Cooktops))
by jrmotter 2/1/2011 6:57:34 AM(UTC)
Left front burner won't ignite (Oven Repair (including Ranges and Cooktops))
by alex1421 9/23/2010 12:26:10 PM(UTC)
Thermador gas cooktop, 1 burner won't ignite (Oven Repair (including Ranges and Cooktops))
by lindam02 5/24/2010 8:48:46 AM(UTC)
Monogram Cooktop burner won't ignite (Oven Repair (including Ranges and Cooktops))
by Jimrs 9/26/2009 10:35:36 AM(UTC)
Bake burner won't ignite (Oven Repair (including Ranges and Cooktops))
by untamedspirit 6/11/2008 5:15:13 PM(UTC)
