My washer does'nt spin.It washes,drains but does'nt spin.The only time it spins is when it is empty.I replaced the electronic board on top.I got it to spin twice with 2 towles in it in about 10 tries. Ser# is HLT4353286.
See if you can find the tech notes with trouble shooting routines, either under the top or inside the bottom panel.
A probable cause is your motor control board, but it is very expensive and you do not want to replace it unless you are sure that is the problem.
Originally Posted by: cdodge ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My washer does'nt spin.It washes,drains but does'nt spin.The only time it spins is when it is empty.I replaced the electronic board on top.I got it to spin twice with 2 towles in it in about 10 tries. Ser# is HLT4353286. I got the tech notes and ran A diagnostic test and everything worked it would even spin at high speed. I cant get A erroe code. Plus now I can't make it run the clean washer cycle without A F34 code with nothing in it.
Well, based on this information I would suspect the main board, but you have already replaced it.
It is possible, maybe even likely the main board you received was defective, and I would see if you can get an exchange on it. That way you will either have it fixed or know for sure the main board is not the problem.
I replaced the ccu board and the touch pad board. What next? There is no change.
See if there is anything in the tech notes about testing the motor control unit.
