bearc0025
#1 Posted : Friday, December 6, 2013 5:15:00 PM(UTC)
bearc0025
10 year old dishwasher - the arms aren't spinning. And they aren't spraying.
It fills w/ water (and drains) fine - I don't know how much water should be in there, but it seems pretty full.
The arms spin well by hand.
I removed the lower arm and cover and cleaned everything out. I put it back together, but it still doesn't spin.
When I open it, it sounds like there's a motor winding/spinning down.
From what I've read, removing what I did seems like it should work.
Thanks in advance for help. I can provide pictures if that would help. Thanks!
bearc0025
#2 Posted : Saturday, December 7, 2013 5:50:28 AM(UTC)
bearc0025
I think it's actually the impeller sleeve that connects to the motor that's stripped. The motor seems to spin, but the impeller doesn't (though it kind of wobbles.
I took the motor out and tried to reconnect the sleeve, but it seems to be stripped too much.
