dgfreyman
#1 Posted : Thursday, December 5, 2013 10:10:50 AM(UTC)
dgfreyman
This unit is a double oven recessed into the wall. Recent problem is that the cooling fan does not run when I set the top oven. The heating elements seem to active on the upper oven. (The cooling fan for the bottom oven does run when I set the bottom oven to bake. Are these the same fans?) I haven't let the upper oven run long enough without the cooling fan to see if it comes up to the set temperature. Could this be a control panel issue?
#2 Posted : Friday, December 6, 2013 1:26:05 AM(UTC)
Parts for Whirlpool KEBS277DWH2 Wall Oven - AppliancePartsPros.com
see the attachment for the tech sheet.
The tech sheet does show separate blowers for each oven.
Also the Relay Logic table indicates that the blower should come on in all heating modes.
File Attachment(s):
KEBS277.pdf (817kb) downloaded 13 time(s).
dgfreyman
#3 Posted : Friday, December 6, 2013 5:30:16 AM(UTC)
dgfreyman
Thanks for sending the tech sheet. I have a follow-up question. How should I troubleshoot this question to see if the problem is the upper oven fan motor or the control panel? So far I haven't seen any error codes on the panel.
#4 Posted : Friday, December 6, 2013 7:16:49 AM(UTC)
[COLOR="Blue"] How should I troubleshoot this question to see if the problem is the upper oven fan motor or the control panel?[/COLOR]
I would check across the relay contacts at the control board (P4-6 to P7-1).
You should see 120 volts.
If no voltage,then the problem is likely the blower re: no continuity.
If there is voltage then start a bake cycle.
The voltage should drop to 0.
If yes and the fan does not run then odds are it is a fan problem.
Check the fan.
If the re is no change in the voltage then it is probably a control board problem.
Be very, very careful when doing the above.
[COLOR="Blue"]
So far I haven't seen any error codes on the panel.[/COLOR]
I do not think they monitor the fan so you probably would not see an error code.
dgfreyman
#5 Posted : Friday, December 6, 2013 7:23:58 AM(UTC)
dgfreyman
Appreciate all of your comments and the plan you laid out makes sense. Not sure if I want to deal with these live circuits, though. Maybe time to call in a professional. If the oven can't be repaired, it's still worth it to pay for an unsuccessful service call considering the cost of a new double oven, including installation. For cheaper appliances, sometimes it is better to just replace it.
Thanks again.
#6 Posted : Friday, December 6, 2013 8:36:04 AM(UTC)
Yes it is not a good idea to learn about electrical circuits running live tests in cramped locations. Especially when there is 240 volts at the board.
Another possibility is to remove power from the unit.
Measure from P4-6 to Neutral.
I am not sure what it should be but you should have continuity as you are measuring the blower motor winding.
If it is infinite ohms then you know it is the blower.
Not as definitive as a live test but a lot safer.
If the above looks OK to confirm that it is the board.
You could remove power from the unit.
Place a jumper between P7-1 and P4-6.
Just be sure it will not come loose or short to something else.
Reapply power if the fan comes on then you know it is OK and the board is bad.
Probably best to have another person turn the breaker back on, then if something looks or sounds bad you can give a shout and get the power off quickly.
