mike sentiff
#1 Posted : Friday, February 8, 2008 4:33:09 PM(UTC)
mike sentiff
Here is my problem
I have the hotpoint that dries for a couple of loads then does not dry -- see old thread on subject
I replaced the coils - checked for continuety - and still have the same problem - heats fine for 3-4 loads then load 5 is damp then no heat
It just did it - worked fine on sensi dry for 3 loads-then would not ignite on load 4- switched to timed dry and it ignited but must of gone out as the clothes did not dry.
I need an idea - ??timer switch
Mike
#2 Posted : Saturday, February 9, 2008 3:31:06 PM(UTC)
Hi Mike,
It should be the hi limit thermostat (#530 on the drum and duct break down diagram).
- The part number for the hi limit thermostat is AP2042686
To make sure this is the beast- you have to check it for continuity right at the time when the dryer stopped heating.
Here are the break down diagrams for the GE dryer Model DLL2450RAL
Guest (4)
