The washer has been sounding very loud when spinning out and now the drum seems real loose. Do you think we could buy parts to fix this problem or not? My husband was going to disassemble it to see just what is wrong with it but I said I would ask a question to see if you would know what the problem might be. Thank you for your time.
THIS FORUM IS DEAD!!!!!!! |
Yes I made a mistake in my typing and the Model # is MAH5500BWW. Thank you so much for the information and my husband said he will try and fix the rear bearing and also thank your for the information on how to do it.:)
You are welcomew.
You can probably find some videos on this on youtube as it is a common problem. |
