Kenpilot
#1 Posted : Wednesday, December 4, 2013 9:38:28 AM(UTC)
Kenpilot
I have a Whirlpool Quiet Partner ll and the Clean light blinks 7 times during the wash cycle. I've run through the reset procedure found on this website and it runs fine for 1 cycle and then the next cycle I get the flashing Clean light again. I ran hot water at the sink first before starting the next cycle and then ran the dishwasher for a couple mins and checked the water temp and its only 89 degrees. Felt the heater element as well and it isn't warm at all. I also noticed even when the dishwasher ran through the entire cycle after the reset procedure, the dishes were still all wet and were as if they were never dried, even though the Heated Dry was selected. Question is, How can I tell if it's just the heater element that's bad or the thermostat or control board? Thanks for any help!
Mod # DU1100XTPBA
#2 Posted : Thursday, December 5, 2013 12:43:30 AM(UTC)
You need a meter.
Then you measure the heating element for continuity (usually around 20 ohms).
Measure across the thermostat, should be 0 ohms.
If both OK measure the combo at the control board just to be sure it is not a bad wire.
If OK then odds are the board is shot.
Note that some units run just the heater through one of the door switches.
You will have to check the wiring diagram just in case yours does this.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Bosch Dishwasher Not Heating (Dishwasher Repair)
by jesseinpdx 12/8/2021 1:35:27 PM(UTC)
Whirlpool Model WD720PADM3 Dishwasher not heating (Dishwasher Repair)
by DSomers 1/24/2021 1:12:17 PM(UTC)
GE dishwasher not heating.... gdf620hgj2bb (Dishwasher Repair)
by Keeber 1/12/2019 8:32:51 AM(UTC)
Kenmore dishwasher not heating (Dishwasher Repair)
by Blanka182@yahoo.com 1/14/2016 2:10:42 AM(UTC)
Dishwasher not heating after replacing Heating element and thermostat (Dishwasher Repair)
by smbegg 1/4/2016 11:47:09 AM(UTC)
Whirlpool Dishwasher not heating (Dishwasher Repair)
by jml927 6/15/2015 1:17:57 PM(UTC)
Dishwasher not heating/drying (Dishwasher Repair)
by dbearce 7/29/2014 7:08:35 AM(UTC)
Bosch dishwasher not heating up! (Dishwasher Repair)
by babybuddha 6/20/2013 4:24:52 AM(UTC)
Kenmore dishwasher not heating water or drying (Dishwasher Repair)
by abqsteve 1/2/2013 5:18:17 PM(UTC)
Bosch Dishwasher not heating water (Dishwasher Repair)
by MIKEGUS 7/2/2012 7:32:28 AM(UTC)
Dishwasher Not Heating Water (Dishwasher Repair)
by pec329 12/16/2011 5:09:55 AM(UTC)
by misschief 8/12/2011 4:06:16 AM(UTC)
Whirlpool Dishwasher not Heating plus clean light flash (Dishwasher Repair)
by jasone 2/28/2011 8:15:08 AM(UTC)
Frigidaire Dishwasher not heating (Dishwasher Repair)
by planemad1 1/13/2011 1:40:57 PM(UTC)
by Lindagayle428 12/20/2010 6:49:04 AM(UTC)
