When set to 'normal wash', will run fine until about halfway done (about ¾ throughthe wash cycle). At this point the drum stops rotating and water continuouslytrickles in while machine “hums”. Seemsto be stuck at this point. When I change positions on the timer the machine fills,drains and spins normally at these positions. I changed the timer, but it still does the same thing. :eek: Any help would be appreciated.
Thanks!
