sean009
#1 Posted : Wednesday, December 4, 2013 7:53:25 AM(UTC)
sean009
When set to 'normal wash', will run fine until about halfway done (about ¾ throughthe wash cycle).
At this point the drum stops rotating and water continuouslytrickles in while machine “hums”. Seemsto be stuck at this point.
When I change positions on the timer the machine fills,drains and spins normally at these positions.
I changed the timer, but it still does the same thing. :eek:
Any help would be appreciated.
Thanks!
